Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Oneway Analysis
Analysis of Means Methods
• Analysis of Means Charts
Each Analysis of Means Methods option adds a chart to the report window that shows the following:
an upper decision limit (UDL)
a lower decision limit (LDL)
a horizontal (center) line that falls between the decision limits and is positioned as follows:
ANOM: the overall mean
ANOM with Transformed Ranks: the overall mean of the transformed ranks
ANOM for Variances: the root mean square error (or MSE when in variance scale)
ANOM for Variances with Levene (ADM): the overall absolute deviation from the mean
ANOM for Ranges: the mean of the group ranges
If a group’s plotted statistic falls outside of the decision limits, then the test indicates that there is a statistical difference between that group’s statistic and the overall average of the statistic for all the groups.
Help created on 9/19/2017
