Note the following about the Tobit2.jmp data table:
The response variable is a measure of the durability of a product and cannot be less than zero (Durable, is left-censored at zero).
Age and Liquidity are independent variables.
The table also includes the model and tobit loss function. The model in residual form is durable-(b0+b1*age+b2*liquidity). To see the formula associated with Tobit Loss, right-click on the column and select Formula.
Select Analyze > Specialized Modeling > Nonlinear.
Click OK.
6.
Click Go.
7.
Click Confidence Limits.
