With Cereal.jmp displayed, select Analyze > Clustering > Hierarchical Cluster.
Select Calories through Enriched, click Y, Columns, and then click OK.
The Hierarchical Clustering report appears. Portion of the Hierarchical Clustering Report shows a portion of the report. The clusters are colored according to the data table row states.
Select Color Clusters from the Hierarchical Clustering red triangle menu.
Colored Clusters
Similar Cereals in Cluster One
Selecting a Cluster
To see the similar characteristics in the cluster, select Cluster Summary from the red triangle menu.
Cluster Summary
Cluster One Characteristics
Help created on 9/19/2017
