Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Enter and Edit Data
• Assign Characteristics to Rows and Columns
This section describes how to exclude, hide, label, color, or mark rows and columns in order to customize the appearance of points in scatterplots and graphs. You can also lock columns so that they stay in place when you scroll through the data table.
The menu for row actions can be accessed from the following places:
the
Rows
menu in the main menu
right-click on a row
the red triangle in the Rows panel
the left red triangle in the upper left corner of the data grid
Similarly, the menu for columns actions can be accessed from the following places:
the
Cols
right-click on a column
the red triangle in the Columns panel
the right red triangle in the upper left corner of the data grid
Help created on 9/19/2017
