Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Scripting Tools
Using the Script Editor
• Auto Complete Functions
If you do not remember the exact name of a function, use auto completion to see a list of functions that match what you have typed so far. Type part of the name, and then press CTRL-SPACE on Windows (OPTION-ESC on Macintosh).
Suppose that you want to clear your JSL variables, but do not remember the command. You can type
clear
and then press CTRL-SPACE, to see a list of possible clear commands. Select the command that you want to insert.
Autocomplete Example
Help created on 9/19/2017
