where Y is the matrix of response variables, M is the response design matrix, and V is the matrix of eigenvectors of
for the given test. Canonical Y’s are saved for eigenvectors corresponding to eigenvalues larger than zero.
and the vs are columns of V, the eigenvector matrix of
refers to the multivariate least squares mean for the jth effect, g is the number of eigenvalues of
greater than 0, and r is the rank of the X matrix.
where g is the number of eigenvalues of
greater than 0 and the denominator L’s are from the multivariate least squares means calculations.
