Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Model Comparison
Model Comparison Platform Options
• Categorical Responses
ROC Curve
Shows ROC curves for each level of the response variable. The curves for the different models are overlaid.
AUC Comparison
Provides a comparison of the area under the ROC curve (AUC) from each model. The area under the curve is the indicator of the goodness of fit, with 1 being a perfect fit.
The report includes the following information:
standard errors and confidence intervals for each AUC
standard errors, confidence intervals, and hypothesis tests for the difference between each pair of AUCs
an overall hypothesis test for testing whether all AUCs are equal
Lift Curve
Shows lift curves for each level of the response variable. The curves for the different models are overlaid.
Cum Gains Curve
Shows cumulative gains curves for each level of the response variable. A cumulative gains curve is a plot of the proportion of a response level that is identified by the model against the proportion of all responses. A cumulative gains curve for a perfect model would reach 1.0 at the overall proportion of the response level. The curves for the different models are overlaid.
Confusion Matrix
Shows confusion matrices for each model. A confusion matrix is a two-way classification of actual and predicted responses. Count and rate confusion matrices are shown. Separate confusion matrices are produced for each level of the Group variable.
If the response has a Profit Matrix column property, then Actual by Decision Count and Actual by Decision Rate matrices are shown to the right of the confusion matrices. For details about these matrices, see
Additional Examples of Partitioning
in Partition Models
Profiler
Shows a profiler for each response based on prediction formula columns in your data. The profilers have a row for each model being compared.
Related Information
ROC Curve
in Partition Models
Lift Curve
in Partition Models
Help created on 9/19/2017
