Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
JMP Reports
Change the Appearance of Graphs
• Change the Order of Values
Data in a JMP report might not appear in the order that you prefer. To give data a specific order so that it appears that way in a report, assign the column the Value Ordering property before running the analysis, as described in
Value Ordering
in The Column Info Window
If your values include any of the following, they automatically appear in the appropriate order in reports:
January, February, March, April, May, June, July, August, September, October, November, December
Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, Dec
Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday
Very Low, Low, Medium Low, Medium, Medium High, High, Very High
Strongly Disagree, Disagree, Neutral, Indifferent, Agree, Strongly Agree
Failing, Unacceptable, Very Poor, Poor, Bad, Acceptable, Average, Good, Better, Very Good, Excellent, Best
Help created on 9/19/2017
