Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
Choice Models
• Choice Model Report
Choice Model Report
Unless Hierarchical Bayes is selected on the launch window, the Choice Model report consists of the following:
Effect Summary
Parameter Estimates
Likelihood Ratio Tests
Note:
The Effect Summary and Likelihood Ratio Tests reports appear by default only if the data set is small enough for them to be calculated in a reasonable amount of time. If they do not appear, select Likelihood Ratio Tests from the red triangle menu to make both appear.
If Hierarchical Bayes is selected on the launch window, the following report appears:
Bayesian Parameter Estimates
Help created on 9/19/2017
