Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
K Means Cluster
K Means NCluster=<k> Report
• Cluster Comparison Report
The Cluster Comparison report gives fit statistics to compare the various models. The fit statistic is the Cubic Clustering Criterion (CCC). Larger values of CCC indicate better fit. The best fit is indicated with the designation Optimal CCC in a column called Best. See SAS Institute Inc. (1983). Constant columns are not included in the CCC calculation.
Help created on 9/19/2017
