In the following examples, the name column is unhidden, unexcluded, labeled, and locked from horizontal scrolling.
Column( "name" ) << Hide( 0 );
Column( "name" ) << Exclude( 0 );
Column( "name" ) << Label( 1 );
Column( "name" ) << Set Scroll Locked( 1 );
Note: All the messages to set various arguments (for example, Set Name, Set Values, Set Formula) start with Set. The word Set is optional for all messages except Set Name (recall that Name is already used for something else, the command that lets you use unusual characters in a name). Use whichever form you prefer or find easier to remember. The corresponding messages to retrieve the current value of an argument (for example, Get Formula) are the same, except that they start with Get instead of Set, and the word Get is not optional.
To deselect all selected columns, send a Clear Column Selection message to the data table object.
dt << Clear Column Selection;
Set Name lets you name or rename a column, and Get Name returns the name for a column. The following example changes the name of the second column from age to ratio. It then returns the current column name to the log.
col = Column( 2 );
col << Set Name( "ratio" );
col << Get Name;
"ratio"
Similarly, Set Values sets values for a column. If the variable is character, the argument should be a list. If the variable is numeric, the argument should be a matrix (vector). If the number of values is greater than the current number of rows, the necessary rows are added to the data table. Get Values returns the values in list or matrix form. Get As Matrix is similar to Get Values but returns values in the numeric columns.
col << Set Values( myMatrix ); // for a numeric variable
col << Set Values( myList ); // for a character variable
col << Get Values; // returns a matrix, or list if character
col << Get Matrix(<list of column names>|<list of column numbers>|<column range>; // returns the specified columns as a matrix
Column( "name" ) << Values( {Fred, Wilma, Fred, Ethel, Fred, Lamont} );
myList = :name << Get Values;
/* returns {"Fred", "Wilma", "Fred", "Ethel", "Fred", "Lamont", "JAMES", "ROBERT", "BARBARA", ...]*/
Column( "age" ) << Values( [28, 27, 51, 48, 60, 30] );
myVector = :age << Get Values;
// returns [28, 27, 51, ... ]
myMatrix = :weight << Get as Matrix;
// returns [95, 123, 74, ... ]
You can specify value labels in any one of the following three ways. Using the Big Class.jmp sample data table, assume that M maps to Male, and F maps to Female.
:sex << Value Labels( {"F", "M"}, {"Female", "Male"} ); // use two lists
:sex << Value Labels( {"F", "Female", "M", "Male"} ); // use a list of pairs
:sex << Value Labels( {"F" = "Female", "M" = "Male"} ); // use a list of assignments
You can activate value labels by sending Use Value Labels as a message to the column.
:sex << Use Value Labels( 1 );
:sex << Use Value Labels( 0 );
dt << Use Value Labels( 1 );
You can set or get the data type of a column using JSL. The choices are character, numeric, and row state. The following example adds a new column that has a character data type to the Big Class.jmp sample data table.
dt << New Column( "New" );
Column( "New" ) << Data Type( Character );
Column( "New" ) << Get Data Type;
"Character"
col = New Column( "New" );
col << Modeling Type( "Continuous" );
col << Get Modeling Type;
"Ordinal"
col = New Column( "Date" );
Column( "Date" ) << Data Type( Numeric, Format( "ddMonYYYY" ) );
The Format message controls numeric and date/time formatting. The first argument is a quoted string from the list of format choices shown in the Column Info window. Subsequent arguments depend on the format choice. You can also set the field width by itself.
col << Format( "Best", 5 ); // width is 5
col << Format( "Fixed Dec", 9, 3 ); // width is 9, with 3 decimal places
col << Format( "PValue", 6 );
col << Format( "d/m/y", 10 );
col << Set Field Width( 30 );
For date formats, the Format message sets how dates appear in a data table column. To set the format that you use for entering data, or for displaying the current cell when you have it selected for entry or editing, use the Input Format message.
col << Format( "d/m/y", 10 ); // display the date in day-month-year order
col << Input Format( "m/d/y" ); // enter the date in month-day-year order
For more information about date/time formatting choices, see Date-Time Functions and Formats in Types of Data.
Note: Do not confuse the Format message for columns with the Format function for converting numeric values to strings according to the format specified (typically used for date/time notation as described in Date-Time Functions and Formats in Types of Data). Sending a message to an object has a very different effect from using a function that might happen to have the same name.
To get the current format of a column, submit a Get Format message, as follows:
col << Get Format;
col = New Column( "Ratio" ); // create column and stores its reference
col << Set Formula( :height/:weight ); // set the formula
col << Eval Formula; // evaluate the formula
col << Get Formula; // return the expression :height/:weight
To force a single column to evaluate, you can send an Eval Formula command to the column. You can do this inside the command to create the column, right after the Formula clause:
dt << New Column( "Ratio",
Numeric,
Formula( :height / :weight ),
Eval Formula
However, it is best to wait until you are finished adding a set of formulas, and then use the command Run Formulas to evaluate all of the formulas in their proper order, as follows:
dt << Run Formulas;
The Run Formulas command is preferable to the Eval Formula command, because while it is evaluating the formulas, Eval Formula does not suppress the background task from evaluating them again. The formula dependency system background task takes great care to evaluate the formulas in the right order, and RunFormulas simply calls this task until all the formulas are finished evaluating.
If you use random numbers and use the Random Reset(seed) feature to make a reproducible sequence, then you have another reason to use Run Formulas, in order to avoid a second evaluation in the background.
You can manipulate list and range check properties using JSL. The following examples use the Big Class.jmp sample data table.
Column( "sex" ) << List Check( {"M", "F"} ); // set the property
Column( "sex" ) << List Check(); // clear the property
LELE(a, b) |
LELT(a,b) |
LTLE(a,b) |
LTLT(a,b) |
Column( "age" ) << Range Check( LTLT( 0, 120 ) );
All of the operators can be preceded by Not and one of them can be missing. The following example specifies that the values in the age column should be greater than or equal to 12:
Column( "age" ) << Range Check( not( LT( 12 ) ) );
To clear a range check state, submit an empty Range Check(), as follows:
Column( "age" ) << Range Check();
To retrieve the list or range check assigned to a column, send a Get List Check or Get Range Check message to the column:
Column( "sex" ) << Get List Check;
Column( "age" ) << Get Range Check;
Note that you can also use Set Property, Get Property, and Delete Property to set, retrieve, and remove list checks and range checks. See Column Properties for more information.
Get Script returns a script to create the column.
New Column( "Ratio", Set Formula( :height/ :weight) );
Column( "Ratio" ) << Get Script;
Numeric,
"Continuous",
Format( "Best", 10 ),
To preselect a role on a column, use the Preselect Role message. Choices include No Role, X, Y, Weight, and Freq. The Get Role message returns the current setting.
col << Preselect Role( X );
col << Get Role;
To lock or unlock a column, use Lock or Set Lock with a Boolean argument. Get Lock returns the current setting.
col << Lock( 1 ); // lock
col << Set Lock( 0 ); // unlock
col << Get Lock; // show current state
