Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Creating Applications
• Compile Add-Ins with the JMP Add-In Builder
A JMP add-in is a JSL script that you can run anytime from the JMP Add-Ins menu. You can create submenus to group your JMP add-ins and have many levels of menus, if desired.
Experienced JSL script writers can create scripts that extend JMP in many ways (for example, add a custom analytical tool or a user interface to communicate with a database). The JMP add-in architecture simplifies deploying and using these complicated scripts.
You can send co-workers a suite of scripts and tell them how to run them. Another option is sending a single add-in file that any JMP user can install and then use just like any other part of JMP.
As a JMP user, you might be given add-ins to use by co-workers. You can also find add-ins on the JMP website at
http://www.jmp.com/addins
Help created on 9/19/2017
