Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here
is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The conditional predictions are the predictions obtained from the model given by
Options that are appropriate for the model that you are fitting are enabled. See Marginal Profiler Plot for Treatment A for an example of a Profiler. See Profile for Quadrant for Layout A for an example of a Surface Profiler. For more information about the profiler, see Surface Plot in the Profilers book.
