For nominal or ordinal responses, a Confusion Matrix report and Confusion Rates report is given. See Example of a Neural Model Report. The Confusion Matrix report shows a two-way classification of the actual response levels and the predicted response levels. For a categorical response, the predicted level is the one with the highest predicted probability. The Confusion Rates report is equal to the Confusion Matrix report, with the numbers divided by the row totals.
