Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Distributions
Overview of the Distribution Platform
• Continuous Variables
For numeric continuous variables, the initial graphs show a histogram and an outlier box plot. The histogram shows a bar for grouped values of the continuous variable. The following options are also available:
quantile box plot
normal quantile plot
stem and leaf plot
CDF plot
The reports show selected quantiles and summary statistics. Report options are available for the following:
saving ranks, probability scores, normal quantile values, and so on, as new columns in the data table
testing the mean and standard deviation of the column against a constant you specify
fitting various distributions and nonparametric smoothing curves
performing a capability analysis for a quality control application
confidence intervals, prediction intervals, and tolerance intervals
Help created on 9/19/2017
