Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Profilers
• Contour Profiler
Contour Profiler
Explore Contours of Responses across Two Factors
The Contour Profiler shows response contours for two factors at a time. The interactive contour profiling facility is useful for optimizing response surfaces graphically.
Contour Profiler Example
Contents
Contour Profiler Overview
Example of the Contour Profiler
Launch the Contour Profiler Platform
The Contour Profiler Report
Factor Settings and Controls
Response Settings and Controls
Contour Profiler Platform Options
Constraint Shading Settings
Additional Examples of the Contour Profiler
Explore Optimal Settings
Help created on 9/19/2017
