Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Control Chart Builder
• Control Chart Types
Control Chart Types
The Control Chart Builder (CCB) enables you to create several types of control charts (Shewhart Variables, Shewhart Attribute, and Rare Event). To create a chart, you do not need to know the name or structure of a particular chart beforehand. Select the variables (or columns) that you want to chart, and then drag and drop them into zones. When you drag a data column to the workspace, Control Chart Builder creates an appropriate chart based on the data type and sample size. Once the basic chart is created, you can use the menus and other options to change the type, the statistic, and the format of the chart.
Help created on 9/19/2017
