Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Display Trees
• Convert Deprecated Dialog to New Window
Dialog()
is deprecated and has been replaced with
New Window()
and the
Modal
message. Scripts based on
Dialog()
will not run in the future.
The following sections illustrate how to rewrite
Dialog()
scripts as
New Window()
scripts.
Help created on 9/19/2017
