Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Enter and Edit Data
Enter Data
• Copy and Paste Data
Copy and Paste Data
When you paste data from another document into a data table, JMP adds rows and columns as needed. Click on a cell and paste the data.
The data type of the copied content needs to match the data type of the cells you’re pasting into. You can add new columns and paste the data, paste the data into cells of the correct data type, or change the data type of the cells if applicable.
Help created on 9/19/2017
