Note: You can create a factors table for a Covering Array by entering data into an empty table, but remember to assign each column an appropriate Design Role of Categorical. Right-click on the column name in the data grid and select Column Properties > Design Role. In the Design Role area, select Categorical.
You can click Back to impose factor level restrictions and then construct a new design.
Clicking Make Table constructs a design table where you can enter responses. The table contains an Analysis script for the design.
