Click OK.
To start a new project, select File > New > Project. A window appears that shows the untitled project.
Right-click the project (Untitled) and select Rename, and then enter a new name (Finance).
Click OK. The Distribution results are added to the project.
6.
To add the Companies.jmp data table to the project, repeat step 3 and select the Companies data table from the window.
7.
Click OK. The data table is added to the project.
