Select Rows > Row Selection > Select Where.
Select Size Co in the column list box on the left.
Click OK.
6.
7.
Select Tables > Subset to launch the Subset window.
8.
Select Selected columns to subset only the columns that you selected. You can also customize your subset table further by selecting additional options.
9.
Click OK.
The resulting subset data table has seven rows and three columns. For complete details about the Subset command, see Create a Subset Data Table in the Using JMP book.
Select Analyze > Distribution.
Click OK.
Caution: This method creates a linked subset table. This means if you make any changes to the data in the subset table, the corresponding value changes in the source table.
