Select DOE > Classical > Mixture Design.
Click the Mixture Design red triangle and select Load Factors.
Click Continue.
Enter 3 in the Degree box.
6.
Click Extreme Vertices.
7.
Click Make Table. JMP uses the 9 factor settings to generate a JMP table (Extreme Vertices Mixture Design).
8.
9.
11.
Select Edit > Copy, to copy the selected rows to the clipboard.
12.
Click in the first cell of row 10 and select Edit > Paste to add the duplicate rows to the table.
The Plasticizer design with the results (Y values) that Cornell obtained are available in the sample data file Plasticizer.jmp.
