Axis Settings Window for a Numeric (Continuous) Axis
Notes:
Notes:
To add commas to values that equal a thousand or more, select the Use thousands separator option. You must account a space for each comma in the Width box, or else they might not appear. This option is available for the Best, Fixed Dec, Percent, and Currency formats.
Select Reverse Order to reverse the axes by reversing the minimum and maximum values.
The example on the right in Rescale Axis to Enlarge a Plot Section is an enlargement of the point cluster that shows between 80 and 140 in the plot to the left. The enlarged plot is obtained by reassigning the maximum and minimum axis values and changing the number of minor tick marks to 1. (See Extend Divider Lines and Frames for Categorical Axes, for details.)
If the axis Format is set to Date, Time, or Duration, a format menu appears beside Increment. See Selecting the Format for Date and Time Increments. Select which format you want the increments to take.
To change the starting point of the tick marks, enter a number in the Tick Offset box. For example, if the Tick Offset is currently set to 0, setting it to 1 will move all the values on the axes up by 1.
Select Help > Sample Data Library and open Stock Prices.jmp.
Select Graph > Graph Builder.
Drag Date into the X zone.
Drag Open into the Y zone.
6.
For Format, select Date > ddMonyyyy.
7.
Increase the value for Label Row Nesting to 3.
8.
9.
Click Done to see the finished graph.
Example of Label Row Nesting
Right-click an axis and select Axis Settings. Click Font.
Notes:
Select Automatic Font Size to have JMP attempt to decrease the font size (down to a certain minimum) if all of the labels cannot fit at the default size.
Axis Label Row for a Categorical Axis
Select Automatic Tick Marks to turn on tick marks only if one or more labels is hidden (due to insufficient space).
Select Tick marks inside graph frame to move the tick marks inside the graph.
Select Lower Frame to add a frame around the labels.
Select Allow Ranges to enter a minimum and a maximum value, which define the beginning and the end of the reference line. The reference line appears over a range of data.
Click Add. The value moves into the box to the right of the Add button, indicating that it will be placed on the graph. Your changes appear in the Preview window.
Help created on 9/19/2017
