To create a custom shape for bubbles, use the Set Shape() message. You can specify circles, triangles, squares, diamonds, or arrows., If you want a different shape, use the Custom option.
The following example uses the Custom option to create a star shape:
Open("$SAMPLE_DATA/SATByYear.jmp");
Bubble Plot(
X( :SAT Math ),
Y( :SAT Verbal ),
Sizes( :Name( "% Taking (2004)" ) ),
Time( :Year ),
ID( :Region, :State ),
Label( "All" ),
Set Custom Path(
"M0.0000000043773431269,-1.07460777055145 L0.299096856653163,-0.408779440996587 L1.02476323781679,-0.330073659953875 L0.483948891847551,0.160136612800349 L0.633338521445479,0.874607770551445 L0.0000000043773431269,0.511746026223682 L-0.633338539628289,0.874607770551445 L-0.483948883092865,0.160136612800349 L-1.02476323781679,-0.330073713828868 L-0.299096847898477,-0.408779434262213 L0.0000000043773431269,-1.07460777055145 z"
Set Shape( "Custom" ),
Title Position( 505.3, 566.5 ),
SendToReport(
Dispatch(
"1",
ScaleBox,
{Min( 490 ), Max( 580 ), Inc( 10 ), Minor Ticks( 0 )}
Dispatch(
"2",
ScaleBox,
Dispatch( {}, "Bubble Plot", FrameBox, {Frame Size( 619, 336 )} )
