Displays a preview of the dashboard. Click Close Preview on the dashboard to return to the dashboard mode.
Shows or hides the Objects and Properties panels for editing display boxes. See Application Builder Window in the Scripting Guide for details about editing properties.
Deselect to display the dashboard in Application Builder, where you can fully customize the application and write scripts. See Creating Applications in the Scripting Guide for details. Select Dashboard Mode to return to the dashboard.
