Modeling dispersion effects is not very widely covered in textbooks, with the exception of the Taguchi framework. In a Taguchi-style experiment, this is handled by taking multiple measurements across settings of an outer array, constructing a new response which measures the variability off-target across this outer array, and then fitting the model to find out the factors that produce minimum variability. This kind of modeling requires a specialized design that is a complete cartesian product of two designs. The method of this chapter models variances in a more flexible, model-based approach. The particular performance statistic that Taguchi recommends for variability modeling is STD = -log(s). In JMP’s methodology, the log(s2) is modeled and combined with a model that has a mean. The two are basically equivalent, since log(s2)=2 log(s).
