Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Formula Editor
• Edit Formulas
Edit Formulas
If you need to change a formula after you have exited the Formula Editor, right-click the column name in the data table and select
Formula
Help created on 9/19/2017
