Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Scripting Tools
Using the Script Editor
• Edit a Script
Edit a Script
To edit a script on Windows, press the Insert key. You can then type directly over (overwrite) any existing JSL code. Note that this feature is not available on Macintosh.
Help created on 9/19/2017
