Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Enter and Edit Data
Organize Data
• Edit or Delete Cells
To edit or delete the contents of a cell, follow these steps:
Click the cell containing the value that you want to edit or delete.
Press the Delete key.
To edit the value, click the cell a second time, and then edit the cell’s value.
Help created on 9/19/2017
