Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Enter and Edit Data
• Edit the Data Table
Edit the Data Table
This section describes the following actions that you can perform on data tables:
Change the data table name
Lock data tables
Add table variables
Add scripts to the data table
Compare data tables
Help created on 9/19/2017
