Select Analyze > Fit Model.
Click Run.
From the red triangle menu next to Loglinear Variance Fit, select Save Columns > Residuals.
In the InjectionMolding.jmp sample data table, right-click on the continuous icon next to Hold Time in the Columns panel, and select Nominal.
6.
Select Analyze > Fit Y by X.
7.
8.
9.
Click OK.
In this plot it is easy to see the variance go up as the Hold Time increases. This is done by treating Hold Time as a nominal factor.
