Select Help > Sample Data Library and open Reliability/Appliance.jmp.
Select Analyze > Reliability and Survival > Survival.
Select Time Cycles and click Y, Time to Event.
Click Cause Code, and click OK.
Competing Causes Report and Hazard Plot
Fit Y by X Plot of Time Cycles by Cause Code shows the Fit Y by X plot of Time Cycles by Cause Code with the Quantiles option in effect. This plot further illustrates how the alphas and betas relate to the failure distribution.
Survival Plots with Omitted Causes shows the survival plots with all competing causes and without cause 9. You can see that the survival rate (represented by the dashed line) without cause 9 does not improve much until 2,000 cycles, but then becomes much better and remains improved, even after 10,000 cycles.
Help created on 9/19/2017
