Select Help > Sample Data Library and open Hollywood Movies.jmp.
Select Tables > JMP Query Builder.
Click Build Query.
In the Available Columns list, double-click t1.Movie Name, t1.Rotten Tomatoes Score, t1.Audience Score, and t1.Theaters Opening Wknd to add them to the Included Columns tab.
Click Run Query.
6.
In the new data table, run the Graph Builder: Scores by Opening Weekend table script to create a report.
From the report window, select File > New > Dashboard.
Select the Blank Dashboard template.
Double-click the Data Filter(Local) box in the left pane to add it to the dashboard.
Dashboard for Hollywood Movies
Click the Menu Items tab and type Hollywood Movies Dashboard next to Menu item name (the name of the add-in menu item).
Click Save and save the add-in to your desktop.
Click Close on the Add-In Builder window.
6.
From the JMP main menu, select Add-Ins and select Hollywood Movies Dashboard.
The Hollywood Movies.jmp data table is queried, and the dashboard opens to show the local data filter and updated report.
Hollywood Movies Add-In
Help created on 9/19/2017
