Select Help > Sample Data Library and open Health Risk Survey.jmp.
Cluster Summary Report
7.
8.
Click OK in the JMP Alert that appears.
Partial Parameter Estimates Report
Partial Parameter Estimates Report shows parameter estimates for the first 8 variables in the analysis. The new cluster names appear in the report window.
10.
Select Graph > Graph Builder.
11.
Enter In what grade are you as X.
12.
Enter Most Likely Cluster Formula as Y.
14.
Click Done.
Mosaic Plot of Cluster Membership versus Grade Level
Help created on 9/19/2017
