This example uses the Flight Distances.jmp sample data table, which is a distance matrix of flight distances between 28 US cities. You can use MDS to construct a map of the cities in two dimensions that is based on the pairwise distances in the data table.
Select Analyze > Consumer Research > Multidimensional Scaling.
Click OK.
Select the Flight Distances data table.
6.
7.
Select Rows > Row Selection> Select all Rows.
8.
Select Rows > Lable/Unlabel.
10.
Click on the Flip Vertical button.
11.
Click on the Flip Horizontal button.
