The Bands Data.jmp data table contains measurements from machinery in the rotogravure printing business. The data set contains 539 records and 38 variables. The response Y is the column Banding? and its values are “BAND” and “NOBAND”. You are interested in understanding what properties are most likely to contribute to the response.
Select Help > Sample Data Library and open Bands Data.jmp.
Select Analyze > Screening > Predictor Screening.
Select Banding? as Y, Response.
Select the grouped columns grain screened to chrome content and click X.
Ranked Column Contributions
Help created on 9/19/2017
