This example uses the Consumer Preferences.jmp sample data table, which contains survey data on people’s attitudes and opinions, as well as questions concerning oral hygiene. You define specific comparison groups across which to compare the responses to the statement “I am working on my career”.
Select Help > Sample Data Library and open Consumer Preferences.jmp.
Select Analyze > Consumer Research > Categorical.
Select Job Satisfaction and on the Simple tab click Responses.
Select Employee Tenure and click X, Grouping Category.
Specify Comparison Example
Help created on 9/19/2017
