This example uses the Hot Dogs.jmp sample data table. Examine the relationship between hot dog type and taste.
Select Analyze > Fit Y by X.
Click OK.
6.
From the red triangle menu next to Contingency Analysis, select Cochran Mantel Haenszel.
7.
From Example of a Cochran-Mantel-Haenszel Test, you notice the following:
