Select Graph > Graph Builder.
Right-click the plot and select Points > Change to > Contour.
6.
(Optional) Click Done.
The darker areas indicate a higher density of observations. In Contour Plot of Diamond Characteristics, use the crosshairs tool to verify the following:
