This example uses the Pogo Jumps.jmp sample data table. The data, adapted from Aitchison (1986), show measurements for pogo jumps of seven finalists in the 1985 Hong Kong Pogo-Jump Championship. A single pogo jump is the total jump distance in three consecutive bounces, referred to as yat, yee, and sam.
Select Help > Sample Data Library and open Pogo Jumps.jmp.
From the Graph menu, select Ternary Plot.
Select Yat, Yee, and Sam and click X, Plotting.
Example of a Ternary Plot
Using the Crosshairs Tool
Select Finalist in the column list box.
Colors should be automatically set to JMP Default.
Select Standard from the Markers menu.
Pogo Data Colored by Finalist
Help created on 9/19/2017
