Select Analyze > Screening > Association Analysis.
Click OK.
The Frequent Item Sets report shows that 36% of customers purchased avocados. The Rules report in Association Analysis Report shows that 58% of these customers also bought artichokes. Because of the large proportion of customers who follow this behavior, the grocery store management might use this information to strategically locate avocados and artichokes.
7.
Right-click in the Rules report table and select Sort By Column.
8.
9.
Right-click in the Frequent Item Sets report and select Sort By Column.
10.
Select Item Set and the check the ascending order option.
11.
Click OK.
