The data in the Drug Toxicity.jmp sample data table shows the toxicity levels for three different formulations of a drug.
Select Help > Sample Data Library and open Drug Toxicity.jmp.
Select Analyze > Fit Y by X.
Select Toxicity and click Y, Response.
Select Formulation and click X, Factor.
Example of Robust Fit
Help created on 9/19/2017
