Examine Fisher’s Iris data as found in Mardia, Kent, and Bibby (1979). There are k = 3 levels of species and four measures on each sample.
Select Analyze > Fit Model.
Next to Personality, select Manova.
6.
Click Run.
7.
From the red triangle menu next to Manova Fit, select Save Discrim.
The following columns are added to the Iris.jmp sample data table:
Click OK.
