feed = Open Datafeed( );
myScript = Expr(
	line = feed << Get Line;
	If( Length( line ) >= 14,
		x = NumSubstr( line, 11, 3 ) );
		If( !Is Missing( x ),
			dt << Add Row( {thickness = x} )
feed << Set Script( myScript );
dt = New Table( "Gap Width" ); // make a data table with one column
dc = dt << New Column( "gap", Numeric, Best );
// set up control chart properties
dt << Set Property(
	"Control Limits",
	{XBar( Avg( 20 ), LCL( 19.8 ), UCL( 20.2 ) )}
dt << Set Property( "Sigma", 0.1 );
// make the data feed
feed = Open Datafeed();
feedScript = Expr(
	z = Num( line );
	Show( line, z ); // if logging or debugging
	If( !Is Missing( z ),
		dt << Add Row( {:gap = z} )
feed << Set Script( feedScript );
// start the control chart
Control Chart(
	Sample Size( 5 ),
	K Sigma( 3 ),
	Chart Col(
		gap,
		XBar(
			Connect Points( 1 ),
			Show Points( 1 ),
			Show Center Line( 1 ),
			Show Control Limits( 1 )
		R(
			Show Points( 1 ),
/* Either start the feed from the device or test-feed some data
 to see it work (comment out one of the lines):
 feed << Connect( Port( "com1:" ), Baud( 9600 ) );*/
For( i = 1, i < 20, i++,
	feed << Queue Line( Char( 20 + Random Uniform() * .1 ) )
You can further automate the production setting by placing a Datafeed script such as the one above in an On Open data table property. A property with this name is run automatically each time the table is opened (unless you set a preference to suppress execution). If you save such a data table as a Template, opening the template runs the Datafeed script and saves data to a new data table file.
Open Data Feed
Data Feed
feed = Open Datafeed( commands )
Creates a data feed object. Any of the following can be used as commands inside Open DataFeed or sent as messages to an existing data feed object. Data Feed is a synonym.
Set Script
feed << Set Script( script )
Assigns the script that is run each time a line of data is received.
Get Line
feed << Get Line
Get Lines
feed << Get Lines
Queue Line
feed << Queue Line( string )
Stop
feed << Stop
Restart
feed << Restart
Close
feed << Close
Connect
feed << Connect(
	Port( "com1:" | "lpt1:" | ... ),
	Baud( 9600 | 4800 | ... ),
	Data Bits( 8 | 7 ),
	Parity( None | Odd | Even ),
	Stop Bits( 1 | 0 | 2 ),
	DTR_DSR( 0 | 1 ),
	RTS_CTS( 0 | 1 ),
	XON_XOFF( 1 | 0 )
Disconnect
feed << Disconnect
Help created on 9/19/2017
