Select Help > Sample Data Library and open Materials1.jmp.
Select Tables > Transpose.
Select plastic, tin, and gold and click Transpose Columns.
Simple Transposed Table
The original table in Simple Transposed Table has two rows and three continuous columns called plastic, tin, and gold. The transposed table has a row for each of the three columns in the original table, and columns named Row 1 and Row 2 for the original table’s rows. The additional column called Label has the column names (plastic, tin, and gold) from the original table as values.
Select Help > Sample Data Library and open Materials2.jmp.
Select item and click Label.
Transpose with a Label
The values from the item column in the original table are used as column labels in the transposed table.
Select Help > Sample Data Library and open Animals Subset.jmp.
Select subject and miles and click Transpose Columns.
Select season and click Label.
Select species and click By.
6.
Transpose Using a By Group
Help created on 9/19/2017
