Whether you remove or retain outliers, you must locate them. There are many ways to visually inspect for outliers. For example, box plots, histograms, and scatter plots can sometimes easily display these extreme values. See Visualize Your Data in the Discovering JMP book for more information.
Uses the quantile distribution of each column to identify outliers as extreme values. This tool is useful for discovering missing value or error codes within the data. This is the recommended method to begin exploring outliers in your data. See Quantile Range Outliers.
Finds robust estimates of the center and spread of each column and identifies outliers as those far from those values. See Robust Fit Outliers.
