Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Nonlinear Designs
Nonlinear Design Window
• Factors
Factors
The column names used in the model formula are automatically inserted in the Name column of the Factors outline. Each factor’s role is set to Continuous.
For each factor, the Values are initially set to -1 and 1. Or, if you have defined a value using the Coding column property, those values are used instead. You can change these values in the factors outline.
Help created on 9/19/2017
