Use the Continuous or Discrete Fit options to fit a distribution to a continuous or discrete variable.
A curve is overlaid on the histogram, and a Parameter Estimates report is added to the report window. A red triangle menu contains additional options. See Fit Distribution Options.
Note: The Life Distribution platform also contains options for distribution fitting that might use different parameterizations and allow for censoring. See Life Distribution in the Reliability and Survival Methods book.
