Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Bivariate Analysis
Flexible
• Fit Each Value
Fit Each Value
The
Fit Each Value
command fits a value to each unique
X
value. The fitted values are the means of the response for each unique
X
value.
Fit Each Value Report
The Fit Each Value report shows summary statistics about the model fit.
Number of Observations
Gives the total number of observations.
Number of Unique Values
Gives the number of unique X values.
Degrees of Freedom
Gives the pure error degrees of freedom.
Sum of Squares
Gives the pure error sum of squares.
Mean Square
Gives the pure error mean square.
Related Information
Fitting Menus
Help created on 9/19/2017
